Announcement
Collapse
No announcement yet.
Morris MM74L Mag Location
Collapse
Desktop Ad Forum Top
Collapse
Mobile ad top forum
Collapse
X
  • Time
  • Show
Clear All
new posts
  • Morris MM74L Mag Location
    I have an mm74L in an evo and am considering resetting it to hopefully bring the mag body out a little from the headpipe. When against the full advance screw, it is really close to the headpipe. Maybe I shouldn’t worry about it, but I’m just considering adjusting it out to get it a little further away.
    My question I have-is all i have to do is raise the mag body up and rotate the hex socket one flat and lower it back down(reset the timing screws and all that)? Will this get the mag body rotated out from the pipe by doing this? Or do i have to take the mag drive gear off of the cam and rotate it around moving the pin to the other location?
    Thanks
  • #2
    I read from researching you can just lift the body, rotate it and drop it back down - it will move 12 degrees.
    Comment
    300 mobile ad bottom forum
    Collapse
    Working...
    X
