Announcement
Collapse
No announcement yet.
Wireing for dummys question
Collapse
Desktop Ad Forum Top
Collapse
Mobile ad top forum
Collapse
X
  • Time
  • Show
Clear All
new posts
  • Wireing for dummys question
    Ok, ignition switch on bars went to crap on me, tore it apart in the quick shop parking lot and got it back home. The wires were lengthened by previous owner and when i got home i went to trace the ignition switch wire back into the frame so i got less of a wiring mess at the bars, but i noticed they have one if the ignition wires one and start button wire spliced together. Im assuming thats supply power? I want to move to a push button starter anyway. Hows a guy get rid of that split but still get power to everything? Im sure its fairly simple my brains just on a trip right now. Thanks.
  • #2
    After a little more looking sounds like it may be hard to get rid of all the wiring due to the CAN bus setup?
    Comment
    • #3
      first off, what bike - year, make & model.
      Can you make a simple drawing of what ya got... or what ya think ya got.
      if you can help us know what ya got with out us havin' to be guessin', you may get better replies.
      Comment
      • #4
        2004 wide glide. Turn signals seem to be set up the same way. Ill get schematics or a photo later on today
        Comment
        • #5
          ***Dyna Models Wiring Diagram Links Index*** part 1
          2004 ALL EFI FXDWG Dom. & Int. Models, Security Circuit (page 1 of 2) (b&w)
          2004 ALL EFI FXDWG Dom. & Int. Models, Security Circuit (page 2 of 2) (b&w)
          2004 ALL EFI FXDWG Dom. and Int. Models, Charging Circuit (b&w)
          2004 ALL EFI FXDWG Dom. and Int. Models, Horn & Instruments (b&w)
          2004 ALL EFI FXDWG Dom. and Int. Models, Ignition Circuit (b&w)
          2004 ALL EFI FXDWG Dom. and Int. Models, Lights (page 1 of 2) (b&w)
          2004 ALL EFI FXDWG Dom. and Int. Models, Lights (page 2 of 2) (b&w)
          2004 ALL EFI FXDWG Dom. and Int. Models, Starting Circuit (b&w)
          Dyna Glide Models - ***Dyna Models Wiring Diagram Links Index*** part 1 - For recent Wiring Diagram Info please check out this link...
          Comment
          • #6
            Begin free Download
            Free repair manual for Harley Davidson 1999 - 2005 Harley Dyna Models Repair Manual
            Attached is a free bike service manual for a Harley Davidson 1999 - 2005 Harley Dyna Models Repair Manual. Some of these service manuals are PDFs, some are compressed files so you may need third party software to open the manual.
            Workshop Service Manual for a Harley Davidson 1999 2005 Harley Dyna Models Repair Manual, free download from carlsalter.com
            Comment
            • #7
              '04 does not use CANBUS system, luckily for you. So, chop away.
              If you are talking about the run/stop switch on the right hand control, yes, the run/stop switch also provides switched power to the start button. If you want to move the start button, you need only supply it with switched 12V from your ignition switch (or more properly, the ignition or accessory breaker). It doesn't take much current to trigger the starter relay.
              Jim
              Comment
              • #8
ID:	1324348Click image for larger version
                Comment
                • #9
                  Didnt mean to post twice, the green is my ignition wired together, the other is the starter switch itself, the turn signal is same way.
                  Comment
                  300 mobile ad bottom forum
                  Collapse
                  Working...
                  X
