Announcement
Collapse
No announcement yet.
50 pan fork oil change
Collapse
Desktop Ad Forum Top
Collapse
Mobile ad top forum
Collapse
X
Today I decided to change out the fork oil in my 50 pan. The factory manual was entertaining with the instructions on how to build a device to refill the forks. I watched some YouTube videos with guys using turkey basters and pumping the shit out of the forks all night long. So I found an old fork cap in the shop, drilled it out then tapped it with a fitting on the top with a 90 in it cause that’s what was laying around. attached a ounce measurement cup and hose to the fitting. 6.5 oz of fluid then Zip tied the measuring cup to my windshield then pumped the forks half a dozen times while waiting a few sips a Pabst. Worked great, no mess. Maybe this fitting has been posted before but thought I’d share what worked for me. Cheers fellas
[ATTACH=CONFIG]108593[/ATTACH][ATTACH=CONFIG]108592[/ATTACH]Today I decided to change out the fork oil in my 50 pan. The factory manual was entertaining with the instructions on how to build a device to refill the forks. I watched some YouTube videos with guys using turkey basters and pumping the shit out of the forks all night long. So I found an old fork cap in the shop, drilled it out then tapped it with a fitting on the top with a 90 in it cause that’s what was laying around. attached a ounce measurement cup and hose to the fitting. 6.5 oz of fluid then Zip tied the measuring cup to my windshield then pumped the forks half a dozen times while waiting a few sips a Pabst. Worked great, no mess. Maybe this fitting has been posted before but thought I’d share what worked for me. Cheers fellas
My question is doesnt air/fluid just go in/out of the fitting you have now? -
I’m using a long hose attached to the fitting. All the fluid just sits in the cup attached to the hose on the fitting. Then pump the forks and the air sucks it downComment
300 mobile ad bottom forum
Collapse
Comment
