Hello all,
This is my first post here. First anywhere actually. I have been snooping around here for awhile, looking at a lot of the cool bikes. I ride a 79 FLH. I just got another 1200 sporty and hardtailed it. I used the chain conversion thread found here. Awesome!!!. Anyway, I noticed a few questions about putting points into an Evolution sportster. Most people say "Why???" Well, because. Electronic is more reliable. Modern. Needs very little attention. But, points are cool. And it's different. You can carry a set with you, and find them at most auto parts stores. Here is how I did mine.http://www.flickr.com/photos/113675156@N08/11798669023/
1. First remove all the electronic pickup and plate, etc.http://www.flickr.com/photos/113675156@N08/11798844564/
2. Make sure your engine is at the proper firing spot on the #1 cylinder.
3. You will see the small slot where the mechanical advancer indexes on the cam.http://www.flickr.com/photos/113675156@N08/11798851754/
4. This is the back side of the advancer. You can see the small roll pin which fits into the slot of the cam.http://www.flickr.com/photos/1136751...8/11798710763/
5. The advancer is placed onto the cam. Make sure it fits into the index slot.http://www.flickr.com/photos/1136751...8/11798441335/
6. The bolt is then put into the advancer to hold it to the cam, so it will spin with the cam. I just snugged it into it.http://www.flickr.com/photos/1136751...8/11798692883/
7. I use Isky cam lube on the advancer cam for the points. I've used this for years building 426 Hemi engines. This stuff is great. You can use other stuff like Lubriplate, etc. Notice the lube on the advancer cam. There are TWO lobes. The taller one is for the #1 cylinder. This is where you want the points to be when you install them.http://www.flickr.com/photos/1136751...8/11798450555/
8. Place the points/condenser plate over the advancer. What I do is turn the advancer to the advanced position. I did because I placed the engine crank at the advance mark for #1 cylinder. You can also place the engine at TDC and just put the points in that way. It will still fire, but will be really retarded. You'll have to advance it more or your pipes will get pretty hot fast. Anyway, just put the two hold down screws on the plate. Move the whole plate to get a points gap of about .018.http://www.flickr.com/photos/1136751...8/11798471535/
9. now just feed the wire that comes off the points through the cam cover hole. This will get connected to the negative side of your coil. (If it's marked +/-)
10. Now fire it up. You can use a strobe in the timing hole, or tune it by ear.
I know this is a little vague, but hope it helps. I never saw a thread on electronic to points, so I did this with my Iphone.
Comment
