Announcement
Collapse
No announcement yet.
Springer I.D help
Collapse
Desktop Ad Forum Top
Collapse
Mobile ad top forum
Collapse
X
  • Time
  • Show
Clear All
new posts
  • Springer I.D help
    Hey yall, Just picked up a vw trike. It's got a springer front end. It measure's 29" From axle to bearing, 4 1/4" between the legs for the tire. I'm guessing it's considered a narrow glide? I've never worked on a Springer but I'd like to rebuild it. I noticed the top springs are cranked all the way down is this normal? The front tire is a 3x18 with a hub wheel, I'm assuming jap bike wheel. The neck on the trike is 45 degree. Any info, tips, tricks, or opinion on getting her road worty again would be appreciated. Thanks fellers. Hoss
  • #2
    Looks garage built to me. Can't recall any of the builders using that thin flat iron for the trees.
    Comment
    • #3
      looks like SIE R-1 rockers,
Name:	SIE springer, original ad, 4130 Chrome Moly.jpg
Name:	SIE chopper kit, original ad.jpg
      but low spring perch is like Cycles International
Name:	bsa with low spring springer(2).jpg
      Comment
      • #4
Name:	Cycles Int., springers,girder, rigid frames, seats 1978 original ad.jpg
        Comment
        • #5
          got a pic of the other side of the wheel?
          Springer 101: Routine Springer Maintenance
          Here you can see two of the main components that wear on a springer front-end: the rod and the spring cup. Since there is very little movement of the spring cup on the rod, it wears in a specific spot and can cause movement in the front-end."
          Article And Photos By: Chris Callen Originally Published In The February 2018 Issue Of Cycle Source Magazine Whether you ride your springer a lot or if you picked one up at a good deal through a swap meet, basic maintenance and care can take you a long way. Most importantly, with only a few items […]
          Comment
          • #6
            I stand corrected
            Comment
            300 mobile ad bottom forum
            Collapse
            Working...
            X
